Use this procedure to view SBT entries.
The following table defines parameters for the show ipv6 fhs snooping binding command.
| Variable | Value |
| ipv6-address WORD<0-46> | Specifies the IPv6 address for the binding entry. |
| type {dynamic | static} | Shows only dynamic binding entries or static binding entries. |
| vlan <1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
